smokeyco75
Ok folks, I was tinkering on the hot rod today and decided to pop of the valve covers to findicate out the casting numbers of the heads. They turned out to be 336781 which I hear are good heads to work with. I also discovered a broken pushrod. The cause could be one of a few things but since I know nothing about this engine I am assuming the worst at this point. That being a sticking valve as the culprit. With that being said it would mean a rebuild of the heads are in order. Do you folks think they are worth rebuilding or should I shop for aftermarket replacements? I wouldn't be going crazy with them, just a basic rebuild including valves, guides, springs, etc. I was going to replace the springs and seals when I swapped cams anyway. What say you?
