Robert
Banned
Installed new 2 psi check with teflon tape to front brake lines - - jacked up front end, rotated tires by hand only get one or 2 revolutions, this check really keeps brakes tighter (less gas mileage too I assume). Anybody else tried this and noticed how tires don't rotate well ?
Bleeding all brake nipples, get great fluid squirt out of each nipple except passenger side front only get like 2 to 3 drops each bleed cycle (manual bleed with another person pushing on brake pedal while we call out "fully down", "up", and "push" - - - "open" and "tight" so I can tighten and loosen nipples at proper time to keep air out).
Removed brake line from this problem caliper and get great fluid squirt, must be something stuck in caliper ?
Emailed 4 photos to Wilwood to identify caliper model and suggest what caliper rebuild kit I need.
