Welcome to Our Community
Sign Up
Dismiss Notice
Brake light switch question
Discussion in 'Brakes' started by choppedtop, Oct 27, 2014.
  1. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,961
    665
    Gender:
    Male
    Occupation:
    Retired
    Should the pressure type brake light switch be before or after the proportion valve in the brake system? I have started noticing it takes more pressure to light up the brake light after applying the first time. Not sure of the pressure range of my switch.
    Lee
  2. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,900
    832
    Gender:
    Male
    Occupation:
  3. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,961
    665
    Gender:
    Male
    Occupation:
    Retired
    I will probably give that a try. I think this problem just started. I usually always check my brake lights as I back out of the shop, and just noticed this Saturday morning. Thanks for the link.
    Lee
  4. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,727
    935
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Do away with the pressure switch and install an electric one and you will never have any more problems unless you rip it off. I added an angle bracket made from s/s with a hole for a switch from a '79 Malibu S/W. Chevy trucks use the same type switch. Mine even came with rubber umbrella dust seals that keep water out when I get caught in the rain. I drilled two smaller holes to mount the switch to the floor of my bucket and adjusted as needed. Works great!!
  5. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Same here , after 2 failed pressure switches , I installed a mech. type switch ,no problems since...[30K miles & 10 years]
  6. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    517
    Gender:
    Male
    Occupation:
    Retired electrician
    I agree, I have changed several pressure type switches to the mechanical type switch for other street rod friends. However, I suggest that you avoid the one that Speedway sells as it does not hold up well at all. I have the one that Ron Francis sells on both my cars and am very pleased.
  7. bobs66440
    bobs66440
    Expand Collapse
    Mar 9, 2013
    1,065
    212
    Gender:
    Male
    Occupation:
    Graphic Designer
    I have a mechanical one as well. It took a little effort to get it set but so far so good...
  8. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,961
    665
    Gender:
    Male
    Occupation:
    Retired
    Thanks for all the suggestions. I may try one more pressure switch, just due to where my wiring is located. If that don't work, I will replace with the mechanical switch.
    Lee
    Screaming Metal likes this.
  9. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,900
    832
    Gender:
    Male
    Occupation:
    My first pressure switch lasted 20 years...:confused:
  10. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,329
    1,297
    Gender:
    Male
    Occupation:
    Retired
    That one was made before the Chinese got involved! LOL
  11. Francis Blake
    Francis Blake
    Expand Collapse
    Jan 26, 2008
    1,280
    50
    Gender:
    Male
    My car is set up for the plunger type switch, and the one on the car doesn't come on till it is compressed all the way so I think something is in order. Will check Ron Francis and see what they have
  12. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    517
    Gender:
    Male
    Occupation:
    Retired electrician
    The part number for the Ron Francis switch that I use is SW-42, check it out. It cost more but is guaranteed for life. I highly recommend it for worry free operation.
  13. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
  14. Screaming Metal
    Screaming Metal
    Expand Collapse
    Mar 12, 2009
    2,633
    251
    Occupation:
    Pro Engine Builder, Master Welder
    The old pressure ones were good....had good success with then, now, not so much.....
    How many times have you seen a honda motorcycle without brake lights due to a switch failure????? Good ole mechanicals....
    I have about 200 of them in a old cardboard box off old bikes....they are pull type, and the have a spring that once its reached its travel, will stretch. They make for good NOS activation switches also
    Alot can se said about the durability of those mech. brake light switches....
    My horde of the old style hydraulic switches is almost depleated (bought a box of them from Grainger back in the day)....so I'm now going mech.
    #14 Screaming Metal, Oct 31, 2014
Share This Page
SSL Certificate
