Over the last month or so I've acquired most of the major components for the change in direction.
Having the hard parts to measure and play with has confirmed an expected problem. The output rod from the pedal assembly and the input rod on the booster, are misaligned by about 3-1/4". Most of the misalignment is due to trying to keep the bottom of the booster above the bottom of the frame rail. In the vicinity of the booster, the bottom of the frame rail is anticipated to be around 6-3/4" above ground.
With the under seat placement of masters and boosters becoming more common, I expected such alignment issues not to be uncommon. Of course that has proven wrong. Soooo now I have to come up with a safe way to "Z" the rod between the pedal and the booster.
- Speedway Universal T-Bucket Brake Pedal Kit
- MBM Corvette style universal 1" Bore Aluminum Master Cylinder
- MBM ProLine 7" Dual Diaphragm Booster
