Welcome to Our Community
Sign Up
Dismiss Notice
Does your pedal assembly and master stick through the floor?
Discussion in 'Brakes' started by raidmagic, Mar 5, 2022.
  1. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    Yeah, I'm familiar with the concept. What to do about it though? I'd like to think they considered this when designing their frames. Thoughts?
  2. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I’m not sure all manufacturers always think that far ahead! Having the steering box for example sticking down may not be that much a problem as the oil pan may hit the ground first. I remember instances when the steering arm stuck down. That scared the poop out of me thinking about hitting a speed bump or manhole cover and turning the steering wheel at speed! When the part is close to the axle you are not to bad.
    Had a person run a stop sign and hit my left rear tire and rotated the housing out from under the car and it sat down on the oil pan and dug about a 2 foot grove in the street with the drain plug! Stuff hanging down should be avoided at all costs! Sorry! End of rant!
    raidmagic likes this.
  3. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    I'll have to take a closer look at the mounting point and the scrub line.
  4. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Like I said, you will be the Engineer/Designer and if you forget about safety first, then you should have an ambulance follow you around if you build your own. Not the frame kits you buy as all that is figured into their designs.
    These cars are simple but if you go in blind without knowledge or experience, you will be headed for bad juju.
    It's when people want to make things different or their way without that knowledge or skills/experience that makes me want to stay away from that particular build.
    Safety first.
    Dependability second.
    Comfort third.
    Looks last.
    rbsWELDER, Rip VW and lincolnuT like this.
  5. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    Smart thinking, T-Test!!!
    lincolnuT likes this.
  6. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    I didn't design any of this. I bought the frame all welded from RPM.
  7. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    I hope you understand that we're trying to help, not accuse. I believe you can resolve this by having some conversations with Ron. Keep up the good work! And, yes, I have seen some unlikely-looking component mountings that worked just fine. Don't get discouraged.
  8. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    From looking at the picture, it appears that there is very little clearance between the bottom of the steering box and the road! Maybe just to quell our fears, just measure the ground clearance. If there's plenty, we'll all be quiet!
  9. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I like the way California Custom Roadsters does their steering box if I weren’t going with rack and pinion on my project. To also makes the steering wheel angle a little less vertical which is closer to the normal angle of common cars.
  10. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    To wit . . .
    [​IMG]
  11. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    You always find the best pictures to make my ramblings make sense! Thanks Spanky!
  12. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    I don't think raidmagic is using a Corvair steering box.
  13. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    I just don't understand the I'm engineering this wrong when I didn't engineer it
    I have 5.5 inches from the bottom of the steering box to the ground. A little more to the bottom of the pitman arm and that goes up not down. If the tire were to come completely off and I was riding on rim I would have just at 1-1/4" from the bottom of the steering box to the ground. A little more to the bottom of the pitman arm.
    I appreciate you guys helping and wanting to make this a safe build, I want that too, I plan on putting miles on this thing.
    Snicklefritz and Spanky like this.
  14. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    See my response to Spanky, if you need something else measured let me know.
  15. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    According to RPM it is a corvair box
  16. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    Think you are good to go! The first pictures had a lot of us concerned! Don’t want hurt bucketheads if we can stop it!
    raidmagic and Spanky like this.
  17. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    Seems we found the answer. 5-1/2” is plenty of clearance.
  18. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    And conversely, I don't want to be hurt lol.
    Thanks for the info everyone.
  19. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,072
    656
    No sir you have a Vega box.
  20. raidmagic
    raidmagic
    Expand Collapse
    Sep 25, 2008
    360
    56
    Gender:
    Male
    Yeah, I had that wrong, I figured that out when buying steering u joints. Thanks
Share This Page
SSL Certificate
