Welcome to Our Community
Sign Up
Dismiss Notice
BRAKES
Discussion in 'Brakes' started by Buck Osborne, Oct 21, 2020.
  1. Buck Osborne
    Buck Osborne
    Expand Collapse
    Oct 21, 2020
    25
    8
    Gender:
    Male
    I didn't realize how important brakes were until I put a blower on my T.
    rbsWELDER likes this.
  2. Jeff Miller
    Jeff Miller
    Expand Collapse
    Mar 8, 2019
    36
    21
    Gender:
    Male
    And a parachute! LOL
    Do you know how much boost you are running?
  3. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    Brakes and steering are two very important items for a T-bucket. Even a mildly tuned engine can provide enough power to get you in real trouble if not careful. Most of these cars tip the scales below 2,000 pounds, and if you have added power via blowers, multiple carbs etc. you are driving a rocket sled! Fun, but potentially hazardous to your health!
    rbsWELDER and lincolnuT like this.
  4. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    Speed never hurt anybody. It’s suddenly becoming stationary that gives you problems!
  5. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    What Breaks ?
  6. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    What Breaks ?
  7. Matthew
    Matthew
    Expand Collapse
    Sep 27, 2022
    2
    1
    Gender:
    Male
    Yes they are, I am having a vacuum issue. No power. Thinking I need new booster.
  8. AltBantam
    AltBantam
    Expand Collapse
    Aug 12, 2022
    62
    51
    Gender:
    Male
    Buck. What size bore master cylinder are you using? For example, if you are using a 1 inch or great with a manual setup, you might not have enough fluid pressure for stopping. Generally, the smaller the diameter, the greater the pressure is produced with the same amount of force. There is a limit on how small you can go. That's why Wilwood uses 7/8" cylinder bores on many of their pedal setups. You might just need to replace the master cylinder with a smaller bore version if you are running a one inch or larger cylinder bore. Also, the pedal ratio is important for pressure too. If equal force is applied to a pedal with a 5 to 1 ratio as to a 7 to 1, the 7 to 1 will apply more force to the master cylinder do to leverage. This increases fluid pressure, better stopping. Make sure you pedal ratio is at least 6 to1 or higher with manual brakes so you don't need to stand on the pedal to stop. One last note, when was the last time you bled the brakes and or replaced the brake fluid. Brake fluid does not last forever.
  9. LongJohn
    LongJohn
    Expand Collapse
    May 10, 2022
    51
    32
    Gender:
    Male
    Spirit uses 1” bore and 7:1 pedal and they have built a bunch of buckets.
  10. AltBantam
    AltBantam
    Expand Collapse
    Aug 12, 2022
    62
    51
    Gender:
    Male
    Here is part of a Wilwood master cylinder bore to pedal ratio chart. With 100 pounds of force, a 1" bore with a 7 to 1 pedal produces 886 psi. With a 5 to 1 pedal, 633 psi. Swapping to a 7/8" bore with the same 7 to 1 pedal increases psi to 1167, nearly 281 more psi. This is why matching bore and pedal ratio is important. Next is fluid volume then front and rear bias.
    lincolnuT and Spanky like this.
  11. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    I would think fluid volume is the most important. Lots of pressure but not enough fluid to move the calipers or wheel cylinder far enough to engage the brakes might be a problem.
    fletcherson likes this.
  12. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    When I built my wrecker I tried to build the best brakes I could using stock parts. One of the things I did was use a larger bore mc as well as the largest vacuum booster available. I have very little pedal travel and it will put you through the wind shield if not cognizant. Prior to the upgrades, it had more travel and much less aggressive stopping power. I’m also using non metallic, organic pads.
  13. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    Does anybody use the silicone type brake fluid rather than the traditional DOT 3 fluid?
  14. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Not me. I did use it for motorcycles when I had my shop.
  15. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,825
    474
    Gender:
    Male
    Occupation:
    Retired
    Nope only use Dot 3 or 4..............
  16. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    Unfortunately Dot 5 Silicone Fluid creates lots of issues on a street vehicle. Most seals in everyday use are not compatable with the fluid.
  17. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    I've used DOT 5.0 since the 80's and have not noticed any problems. Sure is nice not having to worry about the paint !
  18. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    I wasn’t aware that silicone would negatively affect rubber parts.
  19. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
  20. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    Interesting article on silicone brake fluid. If it acts as the article says it does, seems there’s not much advantage to using it!
Share This Page
SSL Certificate
