Welcome to Our Community
Sign Up
Dismiss Notice
Changing my brake set1up
Discussion in 'Brakes' started by tbucketlar1, Nov 11, 2016.
  1. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I am thinking of changing my brake set up. I wonder if any of you with a total performance bucket post a picture of your brakes and give me any information on your brake system. Thank you
  2. railroad
    railroad
    Expand Collapse
    Apr 8, 2009
    1,027
    109
    Gender:
    Male
    Occupation:
    retired
    A better approach might be, posting what you are currently running and if you have any issues.
    We are a specialized group and like to advise on an issue. We need the issue.
    Just joking. My set up is drum/drum, so I doubt you would be interested. I will be watching this to see what you have and where you go.
    I will elaborate more on what my brakes are, the rear are something like a 74 Nova axle, small drum and do little with the heavy, tall tires I have on the rear. The brakes loose their mechanical advantage to the tall tire. On the front I have Old Ford drums. They are not self energizing, but are 12" drums, I think. The brake shoes are same as used on a 1949 Ford tractor. The lining material has a high co efficient of friction and contribute greatly to stopping ability. It will almost chirp the tires on a hard stop from slower speeds. Worst part of the system is the single master cylinder, especially with no mechanical parking brake. The parking brake is hydraulic also. SEE, you just thought YOUR brakes need upgrading.
    Good luck,
  3. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    I'm running '46 Ford pick-up on the rear and '67 Econoline on the front. Stops like crazy. (Truck Brakes)
  4. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,803
    560
    Gender:
    Male
    Occupation:
    Retired
    The best stopping T-bucket we have is also drum / drum.
  5. tfeverfred
    tfeverfred
    Expand Collapse
    May 26, 2007
    5,058
    582
    Gender:
    Male
    Occupation:
    Receiving Clerk
    Jeeees.. I wish you hadn't posted that. I've been considering drums all around. I talked myself out of it for what I think are good reasons Then I read this. I'm so confused!!!:D
  6. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    Just saw an add from DroppedAxle Joe about self energizing drums. I'll look for a link.
  7. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    Found it. Speedway has the kit for $417. Kinda pricey for me but I'm spending way more than I have to to get exactly what I'm dreaming about! Sweet dreams Fred! After a little thought it seems like '55 Ford p/u had self energising brakes that fit your spindles. Try the HAMB for info. Good luck.
    #7 old round fart, Nov 11, 2016
  8. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I have the wilwood kit I got from total perfect. They work good but squeal real bad.I scuffed the rotors and pads worked good for a while then back to square 1. The master cylinder is below floorThere is no residual or proportion value either it did not come when I ordered everything for my brake I have seen other tp buckets without them and they have same set1up as me and they do not squeal.On my last bucket I had before I had drums all the way around and they were great. I might just go back that way. Does anybody no where I could buy front drum kit. lar do have tp spindles on the front. Thanks
  9. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I was typing my message when old round farther posted his reply Thanks
  10. Spanky
    Expand Collapse
    Jul 29, 2016
    3,088
    2,530
    Gender:
    Male
    I think drums all around work well on a T-bucket because they're so light. Personally, I like the look of discs up front. Just my opinion.
  11. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,534
    1,139
    Gender:
    Male
    Occupation:
    Information Technology (IT) 15yrs, Then Retired
    More detail would would be most helpful, which direction do you want to go with this thread???
    BTW, what do you have, and what do you want to change about it.....
Share This Page
SSL Certificate
