Hotrod46
Has anyone used the Chevy Performance Bowtie Vortec heads. I'm going tomorrow to pick up my 383 shortblock parts and will soon be needing heads.
There have been several reworks of the castings since they were introduced, but looks like the current crop are either 185 cc or 225 cc intake runners. This will not be an all out engine, probably in the 400 HP range. I'm looking at a cam with 225 degrees @ .050 duration and around .520 lift. Lobe seperation will be 112 degrees since I may switch to TB EFI (Holley or Fast) later. CR should be in the high 9's with either of these heads. I'm thinking the 185's would work good on this engine. The engine will probably never see the north side of 6000 RPM and the car will have a T56, so I would like to keep decent low end torque to pull the steep 6th gear OD.
These heads are already set up for high lift cams and come with screw-in studs and oversize valves.
Any info or opinions are appreciated.
I already have an Edelbrock vortec manifold on the shelf, so that's not an issue. I bought it at a swap meet about 7 or 8 years ago and may finally have a use for it!
This engine is going in a light weight OT car (approx. 2400 lbs), but I thought the answers might be of use to someone building an engine for a T. The weights are similar.
