Welcome to Our Community
Sign Up
Dismiss Notice
Cost of paint job
Discussion in 'T-Bucket Body Articles' started by T-Bucket Bob, Oct 3, 2018.
  1. T-Bucket Bob
    T-Bucket Bob
    Expand Collapse
    Feb 5, 2008
    189
    43
    Gender:
    Male
    Is 3,500 sound good for a paint job? It includes labor, body work, primer, and paint.
  2. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,682
    873
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Not to me. Do it your self. Even if you mess up, just sand and repaint. No where near that cost. I know you're not a painter, but better to try and fail than never try at all and be proud of what you've accomplished. JMTCW
  3. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,156
    1,132
    Occupation:
    Retired
    A friend just painted a rail buggy and he used Rustolium and added hardner and thinner and was very happy with it. Flowed out nice dried fast and is very hard. Used 3 parts paint 2 parts thinner 1 part hardner. Cost about $20.
    Randy Steel likes this.
  4. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    @$3500 that's probably not a pro shop , so your results may vary . Some colors/paints are that price alone . Do your due diligence , find out what materials , how much for labor. At that price at a shop you're only looking at about 20 hours labor , that's pretty much a wipe down and spray .....can you say "earl schieb"
  5. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,758
    529
    Gender:
    Male
    Occupation:
    Retired
    You pretty much get what you pay for unless you simply overpay, which happens a lot. Typically heard at a car show..... "Be careful, that's a $15,000 paint job on that car!!!" No, it is a $6000 paint job that you paid $15,000 for.
    John Brazelton and Neshkoro like this.
  6. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Sprayers I know says that a chassis is a pain in the butt to paint. Lots of paint for little area. Getting all around a chassis, in the corners, under and over, side to side etc. Not like a body where you sweep from side to side with a wide fan and cover it in minutes.
    I did mine in cellulose as I'm old school and the chassis was a pain. By the time you cover one part and turned it over the over spray had already started to go off. Just have to keep moving and use thin paint for the wet coat so all the different angles etc will blend. Best way is to mount the chassis on a rotisserie.
    Sprayed the body in 1/4 of the time it took to do the chassis.
    Spanky likes this.
  7. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,682
    873
    Gender:
    Male
    Occupation:
    I used 2 engine stands that I made brackets for that went through bolt holes to mount the frame on so it would not show when painted. Turned body upside down on plastic sheeting and sprayed under side and let dry for 2 days. Then sat body right side up on 4 -- 5 gallon buckets and sprayed it and left for 2 days.. Used hardener in paint and has been good except for some chips and no extra to touch up.
  8. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Couple of trellis worked for me
  9. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,875
    901
    It depends on what this paint job intails. If it’s a disassembly, prep, paint, reassembly, it might be fair... if it’s just a tub spray, I don’t think so. You could buy the tools, material, and pay a helper for less. That’s a lot for a quart of paint... Get other estimates, look at their work, talk to their customers.
  10. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    RPM likes this.
  11. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,875
    901
    You put more faith in those plastic saw horses than I. I had a stack of oak trim stacked on a brand new set... they up and colapsed out of the blue, I had my back to them, cutting with a miter saw... just about had a heart attack! Your body must be pretty light.
Share This Page
SSL Certificate
