Parked the T yesterday for the winter even if it does not get that cold\bad here in north Texas.
45 minutes later, the gas tank is drained and out of car. Battery on trickle charge. Radiator drained and removed. Windshield is stored and top is off. Body came off in about 3 minutes. In others words, I have taken the T down to just engine, transmission and frame.
Several things to do: find and fix two oil leaks; find and fix transmission leak; build paint booth in garage; replace front disc brakes, rotors and hubs; sand, primer, body fill, sand some more and then get on to the task of painting. Going to try the paint process myself ... never done anything like this before. Car has been "gel-coat" since I started.
Target is March to have everything done and back together ... if the winter season is somewhat mild.
