Electric fuel pumps
thomas
I have a holly red electric fuel pump and just don't know where to put it. Any suggestions would be appreciated.
thomas:)
thomas:)
In the back where i showed you i had mine.Only difference You Red me Blue.
LumenAl said:
Clearly must be the perfect spot! :razz:
Since the Holleys are a pusher pump they MUST be mounted close to the tank so i guess we got it right HUH?LOL
I thank you gentlemen, the back is where it shall go.
thomas:)
Where did you get the ABS plastic for the interior panels?How thick is it?How much.Im on the interior of mine and this is the last(for now)step.
I called around in the yellow pages and found a source local... can't remember exactly what it costs, but was reasonable... .060 thickness is very easy to form with heat-gun and is what some interior upholstery guys said I should have used, but I used .125 and admittedly, was much tougher to get it to conform.
Here is a link to a website you can order it from as well. http://www.rplastics.com/abssheet.html?gclid=CIe4hOGep5ECFRUmawodYnUOeg
