Zack
OK guys, I thought all was well when i did my first start up but not so. The engine is backfiring slightly and you can hear it out both exhaust pipes. However, the engine runs beautiful and is advanced to 12 degrees timing. I am running a Skip White small base HEI distributor. It also has a tunnel ram with 2 edelbrock 500's. It is running very very rich and black smokes when i wrap it up and the fumes are so bad it burns my eyes. Could the carbs be causing the backfiring or ignition or a combination of both? I have a friend who is gonna put smaller jets in the carbs but i still don't understand the backfire problem. Any ideas????
