fordsbyjay
For some reason the fan in my bucket gave up the ghost last week. My temps were all over and I finally figured out the fan was working intermittently. Eventually it finally quit. Anyways I stole a Spal 16" fan from one of my other cars, built a shroud, then had to move the rad ahead 2" for more room. They had a shorter fan but it was also too close to the pulleys and was rubbing on bumps etc. I have it drying right now so when I get it all assembled I will post some finished pics. I also redid the mounts. It is a walker radiator and it just uses a single bolt on this flimsy flange for a mount. This contributed to the moving around and hitting the pulleys. I boxed in the mount and welded two studs out the bottom on each side. It sits rock solid in the new mount now.
