Welcome to Our Community
Sign Up
Dismiss Notice
Fiberglass resin to hardener ratio
Discussion in 'Bodies' started by T-Bucket Bob, May 31, 2018.
  1. T-Bucket Bob
    T-Bucket Bob
    Expand Collapse
    Feb 5, 2008
    189
    43
    Gender:
    Male
    85 degrees out
    What's the ratio?
    Thanks
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    Not trying to be cute, Bob, but I've always kinda done it by feel - less hardener for higher temperatures. I don't know of a specific ratio, like there is with paint and reducer.
  3. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    10 drops mekp
    per fluid oz. Of resin. Should give you 15 min +- open time ,..
  4. T-Bucket Bob
    T-Bucket Bob
    Expand Collapse
    Feb 5, 2008
    189
    43
    Gender:
    Male
    So, if I have 4 fluid ounces how many drops would that be?
  5. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    591
    218
    Gender:
    Male
    Occupation:
    Carpenter
    Here's a chart... http://www.silpak.com/pdfs/MEKPRATIOCHART.pdf
    Different companies, temp., humidity, age of the chemicals,thickness of the lay up all play into the "proper" ratio and work-ability . Start with a low ratio first.
  6. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    4x10= 40. You 're kidding right ???
  7. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,072
    656
    It depends on the temperature. Google fiber glass mixing ratio.
  8. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    This can probably be adjusted for smaller quantities also:
  9. RPM
    RPM
    Expand Collapse
    Administrator
    Oct 16, 2007
    5,072
    656
    This is the chart we go by in the shop. Printed it out and taped on the wall, seems to work just fine. ResinMixingChart.jpg
    AusBucket likes this.
  10. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    The resin I bought from tap plastics uses half as much resin. For example: 2 oz of resin to 1 oz of hardener. 3 oz of resin would use 1 1/2 0z of hardener. It has a curing time of 5 hours. This resin can be used in 40 degrees weather & requires a longer curing time. The 5 hours curing time occurs in 80 degrees weather. The resin is epoxy resin.
  11. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    I've found Epoxy Resin to be good to work, with easier to measure out for a start, unfortunately it doesn't play well with Polyester Resin. the job needs to be all one or the other. Haven't done any glassing for a long time now.
    Regards,
  12. nobux
    nobux
    Expand Collapse
    Oct 20, 2009
    47
    28
    The guy I buy my resin and fiberglass matt from has been running a fiberglass repair shop for decades. 2% is the ratio he uses.
  13. Island Girl
    Island Girl
    Expand Collapse
    Jul 21, 2018
    1,072
    1,139
    Gender:
    Female
    Occupation:
    Manager
    That may have something to do with the brand involved . . . .
    Here in the Caribbean, where there's a lot of marine fiberglass work done, everything is done with West System, which is epoxy based.
    Generally, it's fine to use Epoxy over cured polyester, but not the other way around.
    I'd follow the recommendation of the manufacturer of your resin, as far as mix ratios.
    West has a couple different hardeners for different temp ranges, as it's often upper 90's here most of the year.
    All epoxy resins have a much different ratio for hardeners than polyester.
    West has different pumps for each product that dispense exact amounts to always get right mix. . . I should think other brands would also have a similar system
  14. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Yeah Agree, West is a good system. The job I had delaminate was Epoxy over Polyester.
Share This Page
SSL Certificate
