Welcome to Our Community
Sign Up
Dismiss Notice
Firewall
Discussion in 'Bodies' started by Spanky, Aug 30, 2017.
  1. Spanky
    Expand Collapse
    Jul 29, 2016
    3,022
    2,428
    Gender:
    Male
    I notice some of you have shiny stuff on your firewall. I am considering using mirrored acrylic for mine, and was wondering what's the best way to make a template for it? Also, how do you fasten it to the firewall? All suggestions appreciated!
    cooter likes this.
  2. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    I would go for chrome vinyl wrap. If you change your mind its easy to take off. Just as a by the by, I have recently done my window sills (internal ones) in gloss white vinyl wrap for cars. Its really easy to work with. You can reposition it; bubbles and creases either press out or can be sorted with a heat gun, and it leaves no glue residue. Warraty is for 10 years, external use.
    Sills now look like a white lacquered finish.
    G
    George Cato and Spanky like this.
  3. dan nichols
    dan nichols
    Expand Collapse
    Jan 5, 2016
    216
    18
    Gender:
    Male
    Occupation:
    electrician
    i used 22 gauge stainless and engine turned it and threaded the firewall and used button head screws:) seems to be working ok
    lincolnuT likes this.
  4. Hackerbilt
    Hackerbilt
    Expand Collapse
    Dec 21, 2011
    355
    142
    Gender:
    Male
    Occupation:
    Collision Tech
    I used a piece of old aluminum sign, about 1/8" thick...sanded it almost to the point of being able to polish it, but went ahead and gave it a brushed look with red scrotchbrite instead. Then I gave it two coats of lacquer clear to seal it.
    I had planned on a full polish but it had a few minor flaws.
    I liked the brushed look anyway so I ran with it instead.
    Used some poster board to make a good fitting template and transfered the shape over to the aluminum. Cut it with a jigsaw just a little outside the mark and sanded it to size to better control the final shape.
    Stainless screws hold it to the wooden firewall.
    cooter, tfeverfred, Spanky and 2 others like this.
  5. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    516
    Gender:
    Male
    Occupation:
    Retired electrician
    Very nice piece of work. The chrome band behind it really sets it off.
    Hackerbilt likes this.
  6. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    Alloy with the chrome trim works really well.
    Mine... just paint.
  7. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Mine is actually a piece of 1/8" steel plate that is chromed. That's how I acquired it. It was bolted to the tub with button head bolts. It was the only thing between the engine and passenger as the tub was cut out with only about a 1-1/2" flange around the perimeter. I've since changed the tub to have a steel reinforced glass firewall, but plan on reusing the chrome plate and actually incorporated the steel reinforcements inside the tub so they are bolted to it, sandwiching the now glass tub. I plan to use some silicone to prevent any vibration or rattles.
  8. tfeverfred
    tfeverfred
    Expand Collapse
    May 26, 2007
    5,058
    582
    Gender:
    Male
    Occupation:
    Receiving Clerk
    Spanky likes this.
  9. one finger john
    one finger john
    Expand Collapse
    Feb 26, 2009
    1,431
    171
    Have you called to find out how much a fire wall in aluminum would be (approx.).
    John
  10. Hot Rod Tommy T
    Hot Rod Tommy T
    Expand Collapse
    Sep 9, 2017
    27
    12
    Gender:
    Male
    Love the cowl trim!!
Share This Page
SSL Certificate
