Welcome to Our Community
Sign Up
Ron Pope Motorsports                California Custom Roadsters                Spirit Industries                Southern Legacy Freight!
Dismiss Notice
Flex plate
Discussion in 'T-Bucket Engine and Driveline Articles' started by 31 bucket, Oct 11, 2020.
  1. 31 bucket
    31 bucket
    Expand Collapse
    Oct 3, 2020
    28
    3
    Gender:
    Male
    yesterday I tried to start my bucket. Think I have a fuel problem or something. Hard to start. Actually didn't start. Been having trouble starting it. Well starter started to grind. Noticed that the flex plate teeth was rounded off. I think the previous owner had issues with starting it also. So here we go. Obviously I got to change the flex plate first. Then try to figure out why it is hard to start. Thoughts?
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    2,266
    1,338
    Gender:
    Male
    Soon after my bucket hit the road in 2016 I had a similar issue, traced to a toasted Pertronix module in my distributor. In the process of finding the problem, I burned up my starter. If you have an issue with starter/flex plate engagement, be sure you have a match between the two. Modern starters frequently have bolt patterns for both 153 and 168 tooth flex plates. Also, be sure to check the engagement clearance (using an ordinary paper clip) between starter gear and flex plate. The other issue that might cause hard starting is improper timing. Too little initial advance could be the problem.
    James Louis likes this.
  3. 31 bucket
    31 bucket
    Expand Collapse
    Oct 3, 2020
    28
    3
    Gender:
    Male
    Ok I will check it out
  4. Island Girl
    Island Girl
    Expand Collapse
    Jul 21, 2018
    971
    932
    Gender:
    Female
    Occupation:
    Manager
    Spanky made some good suggestions, . . . .
    But I'd back up my troubleshooting process back to a practical beginning point. . . . . Pull the plugs, block open the throttle, pull the coil wire and do a compression test straight away, . . . . . Pull the valve covers too and watch that all the valves seem to move about the same.
    A new to you engine may have all manner of gremlins just waiting to get you. . .
    You need to have some reasonable idea of the relative integrity of the mechanical's condition.
    Stuck or burned valves, or a bad lifter, can be a major cause of hard starting, . . . as well as significant vacuum leaks.
    A compression test can often, at least lead you, towards the problem area.
    If it were mine, and I emphasize that it's just my way to look at things, . . . . . I'd see what the comp test showed, and if anything wasn't what it should be, I'd start from scratch and pull the intake and put a dial indicator on each lifter and verify each lobe's lift, ( 1 or more could be wiped) & the cam timing, as a worn cam drive could have jumped time.
    There's lots of ducks to be sure are all in the row before you can have confidence that the issue is resolved.
    Indycars likes this.
  5. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,673
    765
    That is a very broad question. There are many possible causes for hard or no start scenarios. You just gotta go through the tuning and general troubleshooting steps: Ignition, timing, fuel, basic healthy engine stuff.
  6. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    1,897
    659
    Gender:
    Male
    ASSUMING this is a Chevy then the clearance should be .020" - .035" as shown in
    the graphic below.
    For complete instructions for installing a starter or doing some troubleshooting, read
    the attached PDF file. Obviously not everything in the 2 page article will apply to
    your situation.
    James Louis and Bad Bob like this.
  7. Spanky
    Expand Collapse
    Jul 29, 2016
    2,266
    1,338
    Gender:
    Male
  8. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,173
    496
    Gender:
    Male
    Occupation:
    Retired
    I was going to respond and then I decided you guys have it under control. Besides, there’s so many things that could cause a no-start condition. I can’t type that much!
  9. Bad Bob
    Bad Bob
    Expand Collapse
    Aug 11, 2019
    63
    22
    Gender:
    Male
    Occupation:
    Administrator with rolled up sleeves
    Even though rounded teeth are an indicator of a misalignment, if the engine actually turned over several times but didn't light up, I would fix that to get it out of the way, then check all the other basics first (spark, fuel, finding TDC, etc.)
    At the very least, you will be able to check all those things off of the "tune up" list.
  10. 31 bucket
    31 bucket
    Expand Collapse
    Oct 3, 2020
    28
    3
    Gender:
    Male
    I had my starter checked out and the bendix is not fully ingaging. So hence that problem is going to be fixed. Next will do a complete basic tune.
    rbsWELDER likes this.
  11. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    1,897
    659
    Gender:
    Male
    You may be installing a new or rebuilt starter, but it's still important to take 3-4 minutes
    to check the clearances.
    fletcherson likes this.
  12. 31 bucket
    31 bucket
    Expand Collapse
    Oct 3, 2020
    28
    3
    Gender:
    Male
    Yes. I will be certain to do that. Thanks
  13. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    1,897
    659
    Gender:
    Male
    Do you get better acceleration with your avatar going down hill ? :rolleyes:
  14. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,173
    496
    Gender:
    Male
    Occupation:
    Retired
    Sometimes gravity is your friend.
  15. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,593
    295
    Gender:
    Male
    Occupation:
    Retired
    That's what happens when you brake too hard without a proportioning valve.
    Island Girl, Indycars and choppedtop like this.
  16. 31 bucket
    31 bucket
    Expand Collapse
    Oct 3, 2020
    28
    3
    Gender:
    Male
    Lol. I don't know why the picture came out like that. But saves fuel lol
    Indycars and Spanky like this.
  17. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    1,897
    659
    Gender:
    Male
    Give this one a try.
    Just right click on the pic at the bottom and select "Save Image As ...".
    #17 Indycars, Oct 19, 2020
  18. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,611
    537
    Gender:
    Male
    A lot of forum pics these days are using a newish extension which our old forums dont seem to recognise. I have had to snip the pics and save them as a jpeg to get them to load onto this site.
Advertise with Us! Advertise with Us! Advertise with Us! White Rose Technology Ting Mobile Buy VPN
SSL Certificate
