askiles
So I am having a bit of a problem with my front disc brakes. After some use, the pedal gets more and more stiff, and then is stuck near the top of my travel, meaning the calipers are stuck closed. The wheels will not turn at all. I can open the bleeder and it lets off the pressure, and then it is good...until the brakes are pumped about 10 times. Each time it gets more and more stiff. What would be causing my brakes to do this?? I have driven the car for awhile now, and it just started to do this. They are early GM calipers, early GM master cylinder, and a 2lb residual valve I believe. Is this a bad residual valve?? Any and all help is greatly appreciated!!
