Rod Clements
Considering adding 1/4" spacer plate to my front perch plate. The tie - rod taps the bottom of the front frame rail (I have noticed this by paint marks on the top side of the tie rod). Upon further inspection, the tie rod to frame rail clearance on the driver's side is almost 1/4" less than the passenger side.
I'm not sure the existing pair of u-bolts would be long enough if spacer is added. Speedway Motors stocks only what I have now. Does anyone have any ideas or options on locating some longer U-bolts and what might be causing the tie rod clearance issue on driver's side? * The perch plate is located on top of the leaf springs. Thanks!
