You said that you used a relay, how far from the headlights is the relay, what gauge wire did you use, and where does the relay get its power source? The wire length and size can drastically affect it. The wire is a resistor, smaller wire equals more resistance, larger wire equals less resistance. Think of a water hose scenario... On my dump truck, I installed a relay on each light and powered the lights via the relays direct from the batteries as close to the lights as was reasonable, which was easy because it had two batteries, one behind each headlight, and used heavy gauge wire for the feed from the batteries to the relays, and from the relays to the lights. I triggered the relays with the headlight feed from the switch. I was amazed at how much brighter they were. I know that a bucket doesn't really allow such installation due to battery location, etc, but wire size and where you obtain the power feed to the headlights really does matter. If the power source to the relay doesn't come direct from the battery, that could be contributing to your lights not being as bright as you would like them to be. I'm not familiar with your particular car, just trying to visualize what could be the issue. An easy test would be to run a wire direct from a battery to the lights. If they are brighter, maybe re-examine your wiring scheme, if not, get some of those killer blue led lights that I hate when they are coming at me!
