Help please, speedway interior dimensions
I am trying to figure out if the speedway interior kit will fit my body of which I do not know the mfg. If somebody has the speedway interior could you please advise the following dimensions?
Carpet width:
Height of the side panel at the front, middle and back:
Seat back width:
Width and Depth of seat:
My goal is to get something quick and simple in the car until I have a better idea of what I want permanently. When I emailed speedway all they replied was to try to determine what body it is and contact them.
Thank you
Not to complicate matters, but if you don't get your measurements, you could request speedways body dimensions and compare to yours to see if it's compatible.
The speedway interior did fit but with modification. The back of the seat was fine. Because of the plywood interior walls the seat had to have about an 1-1/2 taken out of each side. I also took a little off the length of the sides in back so the seat back fit a little tighter. I have no upholstery experience and it only took a half day to make the modifications. I will post picks when I get my 10 post in.
