Welcome to Our Community
Sign Up
Dismiss Notice
Infrared light on fiberglass and bondo
Discussion in 'Bodies' started by T-Bucket Bob, Oct 17, 2020.
  1. T-Bucket Bob
    T-Bucket Bob
    Expand Collapse
    Feb 5, 2008
    189
    43
    Gender:
    Male
    Can you use a infrared light on fiberglass and bondo? Chicago weather is getting chilly and I want to make sure it cures.
    Thanks, T- Bucket Bob
  2. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Should be fine to warm up. Don't use open flame. If you can make a temporary cover for the area, it would help. Keep the resin warm before mixing.
  3. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Yes, I use heat lamps to help cure it in cold and damp weather, works good. I steal the chickens heat lights when I need extra, lol... they are NOT amused!
  4. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,487
    745
    Gender:
    Male
    Occupation:
    Retired
    You don't want to piss off the chickens!
    fletcherson likes this.
  5. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    When it's cold in the shop or garage I often make a tent around the area and use small space heaters to help. Old bed sheets, tarps or large pieces of cardboard work well. Make a tunnel to draw cool air into the heater.
    With either body fillers or resins it's all about mixing in the catalyst at a rate best for the temps. It's the chemical reaction of the two that makes it set up and cure. With body filler, you'd have to mix it hotter than normal.
    One thing that really helps with polyester resin is after the layup is done spray the area with a light coat of clear polyurethane. The thin coat makes an atmospheric barrier and cures the layup much quicker.
Share This Page
SSL Certificate
