I've been at it about 3 weeks part time and it's coming along The rearend is in with shocks mounted, The front axle is completed except for the front shock upper mounts waiting to got some weight on the front before finalizing the mounting height of the shocks. The engine is completed along with the trans. I have the sterring column mounts built again just waiting for the engine to be mounted before installing it so i can check column clearances. The Hailbran wheels are at the shop getting BFG radial T.A, on them. The T.As are back order. I want the tires and wheel so i can see what kind of rake the frame will have before installing the engine. Any suggestion please help this is my first build.
