Welcome to Our Community
Sign Up
Dismiss Notice
Lisle 33260 Double Flare Tool
Discussion in 'Brakes' started by Indycars, Apr 8, 2021.
  1. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    I'm going to be running new 1/4 inch brake lines for the front wheels and I needed a
    double flare tool. Since 1979 the TBucket has had single 45° flare on all four wheels,
    but I'm going to be redoing the front lines, so they might as well be a double flare.
    That means I had to buy another tool for the safety of all my family and friends !
    I bought the Lisle 33260 that does single and double flares for 3/16" and 1/4" brake
    lines. Since it's not a do everything flaring tool, it's cost was pretty reasonable at
    about $60.
    33260 Double Flaring Tool 3/16" & 1/4"
    What do think?
    Looks like this tool will do a nice job of double flares.
    choppinczech and choppedtop like this.
  2. ruggs
    ruggs
    Expand Collapse
    Aug 16, 2009
    350
    3
    Gender:
    Male
    I must ask why you are using 1/4 inch ? 3/16 is the norm. Just curious.
  3. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    The master cylinder is from a 60-70's Chevy car. It is 1/4 inch in front and 3/16 inch
    for the rear brake lines.
    The size of the brake line will not make any difference in the way it stops. The only
    difference I can see would be how fast the brake fluid will flow thru the lines. We are
    only talking about tablespoon of fluid. So there is a VERY small difference in time
    to apply the brakes, can you think in milliseconds between the front and rear brakes.
    #3 Indycars, Apr 8, 2021
  4. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    Nice flare, excellent price for a two step tool.
    Indycars likes this.
  5. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    The m/c 1/4" port fed a combination valve/ distribution block , that switched to 2- 3/16" lines , one for each front wheel . A single 3/16" line fed the same combo valve & sent 1 -3/16" line to the rear brakes .
  6. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    Where was the distribution block located, was it more central to the front wheels?
Share This Page
SSL Certificate
