What I do realize is that I'm smart enough & experienced enough, & not foolish enough to take the chance of using an open flame next to , or in the vicinity of , a tank full of flammable liquid.
Sorry, Dave, but your explanation for how the rest of us are not smart enough, experienced enough and are foolish enough fails, by means of your own definition of gasoline being a flammable liquid. That is incorrect. Which is the point I was trying to make, in my first post. You see, I am smart enough enough to know liquid gasoline is not flammable. I am experienced enough to know liquid gasoline is not flammable. I am not foolish enough to think liquid gasoline is flammable.
Once again, gasoline is not a flammable liquid, only the vapors evaporating into the air and mixing with available oxygen are flammable. Gasoline, in liquid form, displaces air. By displacing air, liquid gasoline denies the existence of fire, by displacing one of the required components for fire, that being oxygen. Remember the old fire triangle you learned in grade school, where you had to have a fuel, you had to have a heat source and you had to have oxygen to create fire? Take away any of those three components and there is no way for a fire to be started or sustained.
I get your point, I really do. You are frightened at the aspect of having any source of heat near a gasoline tank. Fair enough. Safety should always be of paramount importance. But tell me, what would have been your reaction, had I replied to you by saying, " Seriously??? You think gasoline is flammable??? Have you lost your mind???
" There is a finer point here, Dave. Please take the time to understand it, as my explanations of these things are generally not well-received.
@T-Test , you are absolutely correct. A tank that is not completely filled with water is a bigger hazard than a tank completely filled with gasoline. Rule #1 with a water-filled tank is to move the torch all around the tank, because there is almost always a fuel vapor pocket that is going to flash up. And yes, I've witnessed several gas tanks repaired in the very manner you describe. No burn scars here.
