I need a quick answer or several quick answers. My t-tub project is using the front suspension of a 66 F100. This tub is going to be something like a hi-boy. I'm leaving the brakes as drum, and I just replaced all the lug nut studs and nuts. I went to tighten all of them to 100 lbs. and two of them didn't take and started spinning. I even used a special too to drive them in strait, so they are seated in the holes, but apparently just enough too small for the holes. Now I can't get them to come lose or tighten up fully. What I'm wondering is, can I take out the spindle's cotter pin, king nut, and bearing to get access to those two studs? I'm thinking that would let the wheel, drum and spindle come off as one piece. Am I wrong? If so, how should I fix this problem?
The plan would be to weld these two bastards in and move on to building my frame.
