Welcome to Our Community
Sign Up
Dismiss Notice
Mechanical to Juice????
Discussion in 'Brakes' started by LRS30, Feb 15, 2008.
  1. LRS30
    LRS30
    Expand Collapse
    Feb 10, 2008
    99
    0
    Has anybody converted an early banjo to juice brakes and if so what year parts did you use to do it....
  2. donsrods
    donsrods
    Expand Collapse
    Feb 8, 2008
    1,454
    48
    Gender:
    Male
    I depends on what year rear you are using. What rear do you have?
  3. Youngster
    Youngster
    Expand Collapse
    VIP
    VIP Member
    Jan 1, 2008
    4,734
    22
    If you are using a '35 to '38 rear end, it's basicly a bolt for bolt swap using '39 to '48 pieces. The Model A rear end is a little weak for the kind of use most car get these days. I wouldn't recomend using one if a later one is avalible. I've never worked with a '32 to '34 rear end but would suspect they would fall into the same catagory as the A. I like to use a master cylinder from an '67 Mustang. The NAPA part # is 101485. It's a drum/drum, non-power unit. Seems to work well with the early Ford brakes.
  4. LRS30
    LRS30
    Expand Collapse
    Feb 10, 2008
    99
    0
    I have 3, 2 are early A rears, and the other is a juice set-up already but its going under my brothers Sport Coupe..I'll probably have a good chunk of cash in one making it a good reliable rear for this project..The first 2 are perfect early mechanical banjos just not sure what to do with them....
  5. Youngster
    Youngster
    Expand Collapse
    VIP
    VIP Member
    Jan 1, 2008
    4,734
    22
    Sell 'em or build a banger!
Share This Page
SSL Certificate
