all-world1
I'm going with '56 F-100 drum brakes on early Ford spindles using Speedway's conversion kit. I've previously blasted the backing plates and primed both the plates and new drums.
Should I have just sprayed those with an engine or other heat resistant paint instead of priming?
The same with the hubs?
Do you paint the non-shaft part of the spindles?
Craig
Craig
