Tjbucket
So, finally fired it up worked on getting timing and carbs dialed in. Several start and shut downs during the timing. Then nothing.....started digging, plugs wet with fuel and no spark. I have power at the distributer, swapped out coils, still nothing. I think the ignitor went bad.....which if that is the case really pis&*# me off because the pertronix distributer is brand new, not even run for an hour. Is there anything that I maybe over looking? I have no ballast, as you are not supposed to use one with it. Simple wiring straight to the coil and leads from the distributer connect to it. Am I missing something? I had spark, it was running then nothing.....
