Hold the phone, stop the presses, don't make another move. First of all, that is not a proper 'url number'. Secondly, it is easier to just use Photobucket's 'Direct' link.
People get easily confused with this, and it is a dead-simple process.
Log into your Photobucket account, and click to view the picture you want to display here.
See the Direct link, the blue arrow is indicating? Place your mouse pointer in the box that contains the URL, or address data (all that http stuff). Left-click, and you will see the box turn yellow, with the word Copied appear. You have just copied the Web address (URL) for your photo to your operating system's clipboard.
Now, click on the browser tab where you have the forum opened up, visit the thread where you want to post the image, or click to start a new thread where you want to post the image.
See the icon my mouse pointer is hovering over? That is the icon that will allow you to wrap your photo's Web address (URL) in the proper BBCode IMG tags, in order to display the photo in a post. Click on that icon.
You will see a dialog box open up, just as above. your cursor will already be inserted into the Image URL box, so press and hold down one of the Ctrl keys on your keyboard, then tap the 'v' key. It will then paste that image's Web address (URL) into the dialog box. Click on Insert and Bob is your mother's brother.
OK, now if I can get you to stick around for a few minutes, I will explain why the Direct link is the proper link to use. Just read and you will learn what is happening and why it is happening.
Photobucket gives you a possibility of four links to use - E-Mail & IM, Direct, HTML, and IMG. In days of olde, the IMG link was the bee's knees. That was then, and this is now.
Let's look at each one of those links. I am going to wrap each link in the forum software's CODE BBCode, so the forum software is not trying to actually parse the links.
Email & IM
Code:
http://s1124.photobucket.com/user/Mike765/media/condo3.jpg.html
That is certainly a URL, but let's look where it is pointing. First you have all the http and .com business. That gets things pointed to the proper Web site server. It is everything that comes after that identifies the actual image location. First, there is a /user directory, and inside that one is a /Mike765 directory, and inside that one is a /media directory, and inside that one is a file called /condo3.jpg.html
There is the problem with that URL, that wee .html extension hanging out there on the very end. The forum software is using its IMG (image) tag, so it is expecting to find a file that is an image. Image files use extensions like .jpg, or .png, or .tif, or .gif, or .bmp. An HTML file is a file that a browser or an e-mail client will parse, when it sees it. So, we have the wrong kind of file.
Direct
Code:
http://i1124.photobucket.com/albums/l562/Mike765/condo3.jpg
Now, look at that URL. The differences are not immediately apparent, at least not until you start to look at the directory structure. Now, we are accessing an /albums directory, and inside that one is an /l562 directory, and inside that one is a /Mike765 directory, and inside that we find a filed called /condo3.jpg
Now there is a URL with an image file in it. We know that because there is an image file extension on the file - .jpg.
HTML
Code:
<a href="http://s1124.photobucket.com/user/Mike765/media/condo3.jpg.html" target="_blank"><img src="http://i1124.photobucket.com/albums/l562/Mike765/condo3.jpg" border="0" alt=" photo condo3.jpg"/></a>
OK, before we go any further, just let me say that none of us, not the members, not the moderators and not even myself can post any HTML code to this forum. Ain't gonna happen. Not today, not tomorrow, not ever. This is the kind of code that a cracker can bury malicious stuff in, so I disallow its use for all members.
However, if you look at the section of code that starts out with img src (shorthand for image source), you will once again see the correct URL for my photo. It's just knee-deep in all the other code (which is not W3C compliant, by the way, as it lacks both height and width attributes) it takes to make an image display on a Web page.
Code:
[URL=http://s1124.photobucket.com/user/Mike765/media/condo3.jpg.html][IMG]http://i1124.photobucket.com/albums/l562/Mike765/condo3.jpg[/IMG][/URL]
As I said, there was a time when this was the link you would have wanted, because it would have consisted only of the opening IMG tag, the image URL (which is correct) and the closing IMG tag. For whatever reason, Photobucket now precedes the IMG code with all of that URL code, and I don't know of a single piece of forum software that wants that added into the mix.
I suppose one of the social networks uses that kind of URL structure, but I know that XenForo, Invision, vBulletin, SMF, MyBB and phpBB3 forums don't.
Now, if you were really slick, you could use your mouse to highlight just the following part -
Code:
and just paste that into the text editor, here on the forums. That opening IMG tag and the closing IMG tag are what that image insertion dialog box are adding to the Direct URL, when you paste it in. So that is an option for you. But whilst you are trying to make sure you've highlighted all of what you need, without highlighting too much, I will have copied the Direct link and will have it copied into the image insertion dialog box. Mind that just because I take the easy way out doesn't make me lazy, it just speaks to an economy of expended energy.
But also mind that my easy way is also the most expeditious way, so being lazy isn't always a bad thing.
Now I am aware some of this sounds like ancient Greek, mixed with a bit of Aramaic, a bit of Arabic (woo-hoo, I hope to be starting my Arabic classes within the month!!
), a bit of Mandarin, and a whole lot of pig Latin, but if you will sit there for a couple of minutes, look closely at the links and read the differences I have pointed out, you
will learn a new trick. It's not as hard for us old dogs as people want us to believe.
Follow my instructions, copy the Direct link and paste it into the image insertion dialog and you'll be posting photos like a pro.
