I upgraded to power brakes.
I'm going to try and be brief in explaining this.
I wanted power brakes, my setup from spirit was for manual. Being that I can't weld or have a welder to try.
I did some google searchs.
I found this site.
http://www.fordfalcon2000.com/restoration/powerbrakes.htm
Use a geo metro power brake booster and master cylinder.
I figured if I can stop a ford falcon, it can stop a t-bucket.
$26 at the pick-a-part and I got it out of a 1994 metro.
Made the hole bigger in the center and drilled the 4 mounting holes, in the mount.
Bolted it in, ran the vacuum, made small brake line changes, bleed the lines. :hooray:Works GREAT.
I found this site.
