Welcome to Our Community
Sign Up
Dismiss Notice
Proportional valves residue valves
Discussion in 'Brakes' started by T-Bucket Bob, Nov 16, 2019.
  1. T-Bucket Bob
    T-Bucket Bob
    Expand Collapse
    Feb 5, 2008
    189
    43
    Gender:
    Male
    Hey guys,
    Do proportional valves or residue valves go bad after sitting? I got my T Bucket under its own power but the front wheels are squeaking and the brake pedal a little spongy.
    Thanks
  2. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    It is a closed system and unless you get moisture in the lines I don't think they will go bad
    Try bleeding the system and clean the rotors and pads. You should be OK.
  3. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    417
    237
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    G'Day Bob,
    Brake fluid absorbs water over time and the system needs flushing every 2 years. I've learnt the hard way that occasional use vehicles suffer way more than every day use ones. I change the fluid out every 12 months on my Clubman because it spends a fair bit of time in the carport. I have had to replace caliper and slave cylinder pistons in the past because I didn't keep an eye on them.
    Regards,
    JetMech727 and lincolnuT like this.
  4. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Could be caliper sticking?
  5. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    That would do it. If the piston can’t move you can’t get the air out.
  6. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Sometimes the brackets or slide sleeves stick from corrosion and the piston will just act like a spring... spongy feel and impossible to bleed. Sitting is hard on machines.
  7. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    That is why you do inspections and maintenance BEFORE you drive the first time after it has sat a long time.
    fletcherson likes this.
Share This Page
SSL Certificate
