Welcome to Our Community
Sign Up
Dismiss Notice
Proportioning valve and residual
Discussion in 'Brakes' started by tbucketlar1, Jul 26, 2016.
  1. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I have a total performance bucket I bought a brake kit from them a willwood single piston with the brake lines. I put it together without the valves they were not furnished so I figured I didn't need them. Now the brakes in front are squeaking I sanded pads and rotors still squeaking some.Should I put valves in and which valves do I buy from where? I want to put the best valves in that you guys have had good success with. I do buy a lot from speedway motors. Thanks for your help.
  2. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I have the wildwood on front drums on back
  3. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Permatex & Loctite both make an anti-squeal compound that you apply to the back of the pads ..
  4. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,837
    594
    Gender:
    Male
    Occupation:
    Retired
    If those are floating caliper brakes like the 175's I think you don't want residual valves. Many years ago I worked for a guy who would fix squeaking brakes (drum) by sticking a soda straw in a bag of powdered portland cement, get about an inch of powder in the end of the straw and then would push it in the brake's star adjustment hole and blow the cement in. Worked every time.
  5. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Bet that de-glazed 'em !:laugh:
  6. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,961
    979
    That's a new one for the home remedy book! I can see how it could work, but how did he think of that?
  7. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,961
    979
    Do you know if the pads are squeaking due to the pads rattling due to no pressure with no pedal pressure, or are they just breaking in? If the caliper is retracting and not holding the pad against the rotor, than you may need to install a residual pressure valve, 2psi, Summit sells them, so does speedway. For the Wilwoods, summit was five bucks cheaper. If the brakes are all new, you may just need to put some miles on them to break everything in. There is a membrane spray that you can buy that you apply the the back of the pads to help remedy noise, permatex and others make it. Check to see if there is resistance on the rotor with no pedal pressure, if not, you likely need the valve.
Share This Page
SSL Certificate
