WMG
Was told when I bought my bucket that it had an early model Chevy S Blazer rear end. Had to replace an axle bearing and when I pulled the axle found that the splines were worn about half way. Need to replace the axles, side gears and other components inside the diff. Crown and pinion do not show ay excess wear. Need to know what to look for to identify what model axle this is. Cannot find any numbers stamped on the housing or tags. Any suggestions what to look for to identify?
