I want to machine a remote master cylinder reservoir and cap out of aluminum. The question I have has to do with expansion. Since the master cylinder itself has the expansion gasket (that will be modified or changed for fittings obviously), does the remote reservoir need anything similar like an expansion gasket or should it have weep hole, check valve, etc...?
