That's the Ford bolt patern. What rear end are you using?
This might help with the bolt circle measurements.
Tyus4,
The mrt-wheel chart is not measuring from the center of both studs. Take a look, one is from the outer edge of a stud, the other from the middle of a stud. It is only an aproximation anyway, since stud sizes vary, and not very accurate. Use GABs chart, it is correct.
Corley
I think you are in the ball park there, but of course it depends on the tires size and amount of side wall bulge.
