Rip VW
I am in the process of setting up my steering shaft on the T. The steering linkage from the bottom of the column to my front frame mount Vega box. I have a Vega spline to 3/4 double D U joint on the box. The bottom of the column has a 1" to 3/4" Double D Dual cardan U joint. (a double joint). the connection between column U joint and box U joint is a 3/4" Double D steering shaft. Oh there is a shaft support bearing on the upper portion of the Double D shaft.
Now looking at the way the DD shaft is secured in each U joint, I am concerned that just a small indentation on the shaft is the way the U joint set screw is supposed to keep the shaft from sliding out. I feel if done this way it will not be as reliable as it could be. I am wondering how deep a person should make the set screw indentations? Anyone have any suggestions on how to secure the shaft? I also entertained the thought I could put a spot Bead to tack the shaft and U joint together that way it could be disassembled if needed by grinding the spot weld..
Either way I have finally got the steering wheel connected to the steering box. I have been a bit slowed over the last couple of months due to a relapse of my bone disease which slowed me to a stop for a while. However I am trying to get out in the shop for say an hour a couple of times a week and I am making slow progress..
So if anyone has any ideas of how to safely secure the steering shaft shout out and lets look at
everything pros and cons...
