one finger john
When setting up a coil over rear suspension, do you figure that suspension sag under normal conditions ( two, 200 lbs passengers plus 50 lbs. fuel) wiil put the shock at approx. 1/3 compression. Or will it be 1/2.
I.E. with a 12 inj shock, should the car settle down to 8 in or 6 in? I have heard that the "sweet spot" is approx. 1/3 of total height
Better yet, how many inches will the whole car settle (when completed) from when first mocked up w/no engine, trans., or fluids.
I would like to make bolt in bars to substitute the rear shocks at the all up ride height.
Thanks in advance, John.
Was I clear?
Was I clear?
