Welcome to Our Community
Sign Up
Ron Pope Motorsports                California Custom Roadsters                Spirit Industries                Southern Legacy Freight!
Dismiss Notice
Temp fluctuation
Discussion in 'T-Bucket Engine and Driveline Articles' started by Butch Bridgers, Sep 2, 2019.
  1. Butch Bridgers
    Butch Bridgers
    Expand Collapse
    Feb 4, 2016
    1
    0
    Gender:
    Male
    Does anyone know what will cause the temp gauge fluctuate?
    After I'm driving awhile the temp gauge will move up and down between 220 and 230 and also between 230 to 240.
    Not sure how accurate my temp reading is.
  2. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    447
    114
    Gender:
    Male
    Occupation:
    Carpenter
    Thermostat getting stuck? Hose getting pinched? Low water (coolant) level?
  3. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,577
    369
    Gender:
    Male
    Occupation:
    Retired
    You may get more views if you move this up to Engine and Drive Line topics. Alot of us don't go this low on the main page very often.
    What are the normal running temps? Surely not that high most of the time. What speeds does this occur? Sitting still or on the highway at driving speed?
    Are you boiling over? Need a bit more info to help with answers and suggestions.
  4. iroct
    iroct
    Expand Collapse
    Aug 21, 2008
    132
    24
    Gender:
    Male
    get a harbor freight pyrometer. check for difference in temp at radiator, thermostat housing and back of block when it is doing this.It will help diagnosing this
  5. Guy
    Guy
    Expand Collapse
    Feb 22, 2019
    390
    80
    Gender:
    Male
    Occupation:
    kinda Retired
    Low coolant or bad thermostats
  6. PotvinGuy
    PotvinGuy
    Expand Collapse
    Feb 22, 2008
    1,535
    372
    Gender:
    Male
    Occupation:
    Is your sender in the top of the manifold? Air in the cooling system can make a pocket around the sender and then sloshing water will make the gauge fluctuate. Try loosening the sender and let out any trapped air. I've seen this and fixed it this way.
    rubicon, Kevinrevin and JetMech727 like this.
Advertise with Us! Advertise with Us! Advertise with Us! White Rose Technology Ting Mobile Buy VPN
SSL Certificate
