Welcome to Our Community
Sign Up
Dismiss Notice
Thread Sealer
Discussion in 'Brakes' started by PaulR, Dec 14, 2007.
  1. PaulR
    PaulR
    Expand Collapse
    Dec 14, 2007
    304
    33
    Gender:
    Male
    Occupation:
    Piping Designer / Cad Coordinator
    Evening, I'm looking to bend, route my own lines on my T Bucket. The question I have is, am I to use any type of thread sealer on any of the threads when I bolt them up? This is my first of many questions as I'm just getting started.... Thanks in advance.
    PaulR
  2. tfeverfred
    tfeverfred
    Expand Collapse
    May 26, 2007
    5,058
    582
    Gender:
    Male
    Occupation:
    Receiving Clerk
    Your brake lines should have AN fittings and they won't require thread sealer. I did need to use a piece of thread tape on a brass fitting going to my brake light switch. Even then, it was only a little strip. Try without tape first. Idealy, you should not need it.
  3. PaulR
    PaulR
    Expand Collapse
    Dec 14, 2007
    304
    33
    Gender:
    Male
    Occupation:
    Thanks, I'll try it.
  4. Mike
    Mike
    Expand Collapse
    Oct 23, 2006
    5,635
    514
    Gender:
    Male
    Paul, here's the trick to remember. Use thread tape on pipe fittings. Inverted flare fittings seal on the flare, as do AN fittings, so no tape is needed there. Pipe thread is the only place you need it, because the taper in the threads is the sealing sirface.
  5. PaulR
    PaulR
    Expand Collapse
    Dec 14, 2007
    304
    33
    Gender:
    Male
    Occupation:
    Thanks, It makes sense to do that. I was not sure.
    PaulR
Share This Page
SSL Certificate
