Tiger Hair/ Fiberglass
debgeo
I am reworking a cowl for my c-cab. It has some voids that have beem repaired with tiger hair. My question is can I fiberglass over the tiger hair?
THANKS George
Absolutely! Tiger Hair is simply a polyester filler (originally made by Evercoat I believe) that has glass strands within the solids. You can definately apply a polyester resin based mat or cloth over this substrate with no problem. :cry:
Yep, and as with any fiberglass repair, you will want to wipe it with acetone first, then scuff it with some sandpaper, and wipe it down again with more acetone. Resin cures by wax rising to the surface, so you need to remove that wax for good adhesion.
Yep its no big deal to go over tiger hair.
.by the way debgeo can you post a bigger pic of your avatar for me ,i am planing another build this winter and that pic has me thinking:D!
Here you go found on internet. I am using this as inspiration for c-cab I am building. Presently building body.
