Welcome to Our Community
Sign Up
Dismiss Notice
Tilt Wheel In A T Bucket ??
Discussion in 'Bodies' started by datonamanmike, Dec 29, 2007.
  1. datonamanmike
    datonamanmike
    Expand Collapse
    Feb 1, 2007
    99
    0
    i wanted to get a tilt column for my bucket
    but the guy from total told me it wouldnt
    work
    i assume this is because there is no column
    drop from the dash but im sure iv seen buckets
    with tilt
    so my question is
    is the mounting plate at the bottom
    strong enuff to support the tilt column ??
    i think it is but im open to all sujestions
    thanks in advance !!!
  2. thomas
    thomas
    Expand Collapse
    Apr 29, 2007
    619
    0
    Mike, I have a Spirit Kit and I purchased a tilt steering column with my kit. If you check my gallery I believe I have a picture of it.
    thomas:)
  3. datonamanmike
    datonamanmike
    Expand Collapse
    Feb 1, 2007
    99
    0
    i see yours comes throu the firewall mine bolts to the floor with a plate type thing still unsure bout this
  4. Rick
    Rick
    Expand Collapse
    VIP
    VIP Member
    Apr 16, 2007
    2,097
    6
    Gender:
    Male
    I don't see any reason it would'nt work as long as it's 13/4 diameter tubing.Flaming River sells one made for hot rods.Just don't be hanging on it.LOL
  5. thomas
    thomas
    Expand Collapse
    Apr 29, 2007
    619
    0
    You would still need a column drop with a tilt, but that should'nt be a problem. Just mount your column drop to the back side of your dash.
    thomas:)
  6. tbucketlar
    tbucketlar
    Expand Collapse
    Nov 4, 2007
    71
    0
    Mike, On my previous bucket there was a tube column something like the total setup that was alful looking. There was a 3/4 piece of plywood fiberglassed to the firewall. We made a little bracket mounted it to wall and mounted the column bracket to it and steering column to it. It ended up being pretty solid & sturdy. I am going to do the same thing to my new bucket plus it adds a little strenght to the body. Maybe you can do something like this. Thanks Lar
  7. Rick
    Rick
    Expand Collapse
    VIP
    VIP Member
    Apr 16, 2007
    2,097
    6
    Gender:
    Male
    In the stock column there is no column drop so i don't see a real need for a drop for a tilt one the bracket is mounted pretty solid to the floor also i made my own and welded the tube to the bracket just for that reason i didn't like the play in it.i can pull pretty hard on the column and it does not move abit.Just a thought guys.
  8. tbucketlar
    tbucketlar
    Expand Collapse
    Nov 4, 2007
    71
    0
    Rick, the tilt column I used was made by ididit it was kind of heavy on the top especially with the wheel on it. I didn't try it without the column drop bracket so maybe it would work without. Lar
  9. Youngster
    Youngster
    Expand Collapse
    VIP
    VIP Member
    Jan 1, 2008
    4,734
    22
    I have seen 3 cracked steel 'vair boxes over the past years and none of them had a column support. I always use a mount like tbucketlar described.
    Youngster
  10. lanceks1
    lanceks1
    Expand Collapse
    May 27, 2007
    55
    0
    I have the Spirit with the tilt, and I just hung the drop from the back of the dash. It is alot more comfortable than having to reach for it. It's also got a floor flange, and seems very ridgid.
Share This Page
SSL Certificate
