Welcome to Our Community
Sign Up
Dismiss Notice
Track Bucket build
Discussion in 'Project Plans & Updates' started by thebearded1, Oct 15, 2022.
  1. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,852
    770
    Gender:
    Male
    Occupation:
    Best to use the "upload a file" button for pics.
  2. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    re-uploading photos of the friction shocks
    rbsWELDER likes this.
  3. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    Finally got the new intakes on the car and the carb hooked up only to discover the carb has a leak in the throttle shaft. I figured i would have a go at adding some bronze bushings to the carb body to fix the problem but when I took apart the base plate I found the throttle shaft was heavily worn and i could feel the edge where it was worn down. Found someone on another forum that has another Holley 2280 so i may get that one and swap the rebuild kit over. Or if the throttle shaft and base plate look good i may just switch them over to the carb i have.
  4. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    Given what you've found on the shaft, it's odds on that the holes on the body casting will have wear also. If it's a separate base then you only need a replacement base.
    lincolnuT and Spanky like this.
  5. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Parts are available. Chances are the throttle plate is egg shaped as well.
  6. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    It's hard finding parts for the holley 2280s. I had a few folks offer up old carbs for $50 but it's a gamble if those have a a decent shaft or base. I got the holley 2280 for free so i will only be out the $25 I paid for the rebuild kit. I ended up going with a NOS Stromberg WW carb someone on the slant six forum had. He has used 2 of those carbs before on 225 slant sixes and another member also used one on theirs with no issues. I will post updates once i get that carb and try it out.
    fletcherson and Spanky like this.
  7. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    I got the Stromberg installed and it runs great! I was even able to get it to idle at 425 rpms! Now I have to work on hooking up the throttle and kickdown cables, making a bracket for them and it looks like i will need to shorten the throttle cable and housing. Hopefully I will be able to get something together relatively easily. Then the car will be driveable again and I can take it over to my buddy's for some more welding.
  8. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    Spanky and choppedtop like this.
  9. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    This is the regular idle at 750 rpm. I still need to adjust the idle air mixture screws to get it even better. Haven't done it yet since I need to add a length of 1/4" brass tubing to the manifold vacuum port so I can hook up my vac gauge.
    https://youtube.com/shorts/GfQjRGlOtQA?feature=share
    Spanky likes this.
  10. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    Making some slow but steady progress. I made a bracket setup for the throttle and kickdown cables and the return springs. The 2 barrel carb drives nice and has a lot more pep. The next warm day I will take it down to my "testing grounds" and use the Drag Racer app to see if i turn a better 1/8 mile time.
    I made a bracket for the seat belts too. It's hard to see in the photo but it's 1/4" steel with gussets for the tabs. There is another piece of 1/4" steel the same width and length on the backside of the body. The 2 pieces sandwich the back body using 7/16" grade 8 bolts. Later on when I add a roll bar that is tied into the frame i will tie this bar into the roll bar. I'd eventually like to run this car at one of the Loring Timing Association's land speed events in Maine to see what it will do which is why I want to add the rollbar. I will have 4 point seat belts in it by then too.
    Last night I upholstered the seat back. It's 4" foam with badding attached to 1/4" birch plywood. I will screw another piece of 1/4" plywood to the body and use velcro to hold it in place. I was even able to get the stripes to line up! Now I'm going to make a thinner pad at the top to help fill in the gap between the body lip and seat back. It will be 2" foam and tan fabric.
  11. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    Nice work! ...... Wish I could do upholstery.
  12. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    61
    66
    Gender:
    Male
    Thanks! This was my first time. I just kept refolding the corner and trimmed a little excess fabric off each time till i got the corners how I wanted them to lay. It was fun figuring it out.
  13. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    It's a very clean looking job Gene.
    thebearded1 likes this.
  14. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,924
    631
    Gender:
    Male
    Occupation:
    Retired
    Rick, I am still learning how to sew stuff up. Here is the seat that I did for the Econoline project. Almost done now and all that is left is the carpet.
    thebearded1, AusBucket and lincolnuT like this.
  15. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    I sure would like to come see you next winter if the Universe + the moons and stars align !!!
  16. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Very nice work on those seats. I tips me lid.
    thebearded1, lincolnuT and choppedtop like this.
  17. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    Could you take a pic of your lid, sure would clarify a few things for us in the States ???
    Or would that be too scary for us to contemplate, once we looked in ?
    AusBucket likes this.
  18. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,216
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I was wondering where I was going to get my interior done! Lol
  19. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    G'Day Indy, It's a very old saying English in origin and given as a compliment, as in, "I doff (tip) my hat to you". I tip's me lid.
    Indycars, lincolnuT and Spanky like this.
  20. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Indycars and lincolnuT like this.
Share This Page
SSL Certificate
