I need help designing a trailer hitch that comes off the rear end , with 2 people in the car I don't need anymore wieght hanging on the frame. All drawings welcome
A trailer hitch should not be mounted to the rear end on a street driven car... IMHO most radius rods, swaybars, etc. and their mounts are not built to take direct trailer weight, but anything is possible...
If your trailer is designed right there should not be very much tongue weight anyways. Mounted to the rear end the tongue is going to be going up an down like crazy. Ever see a video of suspension as it goes over bumps?
There used to be a trailer hitch that attached to the rear diff., with a pivot. It then was held up by the rear bumper. It allowed for the pulling forces to come from the diff., and the lifting forces only, from the bumper. There was another version of it that would swing from side to side at the bumper, effectively making the trailer toung apear to be hooked right at the diff, making backing a trailer easier. (It didn't use a ball hitch at the trailer.) Does not apply in this case, and they both were a real piece of s__t in my estimation. If you can't handle the weight off the frame, you need to beef up the springs, because pulling from the diff. is not a good idea due to the up and down motion it will impart to the trailer. It will shake your beer into foam!
