Joe-405
Here use this as a guide...............
Easily installs 11" rotors and the 1978-up GM Metric calipers to your 1937-48 Ford passenger car and 1937-47 1/2 ton Ford spindles. No machine work needed. This kit works well with bolt-on steering arms. The 11" rotor brake kits are great for street rods based on 1932-48 Fords. Uses Ford/Mopar wheel bolt pattern of 5 on 4-1/2".
Also if you go to the link it gives every part number to make it all work............
http://www.speedwaymotors.com/Disc-...-Early-Ford-Spindle-5-on-4-1-2-Inch,4575.html
