Do you have to hit a bump @70 mph to induce the hop or does it just start to hop as you approach 70? Have you put a dial indicator on the front rims? Have you checked the run out of the front TIRES? Were the tires balanced on the car? Could the brake discs be out of balance?ok new hyd. shocks new spring balanced tires and still got tire hop at 70mph why????????????????????
it starts as you get up to 70 on smooth road. the tire were balanced off the car. can't find anyone who does it on the car around here. the tires appear round when balanced but have not turned them slow with any type of gauge I know i can jack it up and use aboard or something as a gauge.Do you have to hit a bump @70 mph to induce the hop or does it just start to hop as you approach 70? Have you put a dial indicator on the front rims? Have you checked the run out of the front TIRES? Were the tires balanced on the car? Could the brake discs be out of balance?
Drive @ 65 mph to a tire dealer that does on-car tire balancing. Mark the wheel position on the hub so that when (not if) you remove the front rims/tires they will be put back in the same position. Also mark left/right wheel position. Heck, while your at it, mark the rears and balance them too. Since I don't know where you are, I can't tell you where to take your rod to have the tires balanced. Are you near a big city? Maybe a truck stop? A telephone to call around the area? A computer that is connected to the internet? It shouldn't be that hard to find a shop that does on-car balancing.it starts as you get up to 70 on smooth road. the tire were balanced off the car. can't find anyone who does it on the car around here. the tires appear round when balanced but have not turned them slow with any type of gauge I know i can jack it up and use aboard or something as a gauge.
I have had the exact issue several times on different vehicles all sharing a common item.Try dropping the rear tire pressure say from 28 to 15 then take it out for a test drive and see how it changes.Do not change the front until after testing on the rear and adjusting rear to max press below vibration point,then when satisfied with rear feel turn attention to the front if needed.This is for reasons as Dave mentions but helps for those of us that don't wish to continue to trade tire sets till finding that good set.
