Welcome to Our Community
Sign Up
Dismiss Notice
Weak Rear Brakes
Discussion in 'Brakes' started by bobs66440, Apr 30, 2015.
  1. bobs66440
    bobs66440
    Expand Collapse
    Mar 9, 2013
    1,065
    212
    Gender:
    Male
    Occupation:
    Graphic Designer
    Another update: I drove the car to a show yesterday, about 160 miles total, so I was really able to evaluate the brakes. The bias is just about perfect but the pedal effort is about 10%-15% more than I had initially thought. Not the end of the world, but it's noticeable and significant for me since it was a very hard pedal before this. I think a power booster is in my future. Otherwise I'm very happy with it.
  2. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,073
    657
    Maybe just make the pedal longer to change the pedal ratio.
  3. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    ^^^^^^^ or get a more compatible M.C.....
  4. ellis8500
    ellis8500
    Expand Collapse
    Nov 24, 2009
    958
    77
    Gender:
    Male
    Occupation:
    Engineer
    I have GM metric front calipers and Ford Explorer rear calipers coupled to a '75 Corvette 4-wheel disk manual MC. Front pistons larger than rear pistons. System is self-proportioning. Pedal pressure is not at all high.
  5. bobs66440
    bobs66440
    Expand Collapse
    Mar 9, 2013
    1,065
    212
    Gender:
    Male
    Occupation:
    Graphic Designer
    A longer pedal would be easy, but I would have to hack up the floor so that's not an option. A more compatible mc is a good idea, but which one is more compatible?
  6. Hotrod46
    Hotrod46
    Expand Collapse
    Aug 22, 2007
    759
    79
    You could go with a smaller bore MC. I think that there is a corvette style MC with a 7/8 bore available (if not there are others). The only drawback to the smaller bore is that your pedal travel will increase since you have to move the same amount of fluid with a smaller piston.
    For safety, you need to make sure that you can move the MC a full stroke with no fluid in it. That's the only way to verify that a dual circuit MC will function correctly if you lose pressure on one end.
    If you go with the corvette style, you will probably need a 10 lb. residual valve in the rear line, since they are usually disc/disc.
    bobs66440 likes this.
Share This Page
SSL Certificate
