clamper
O.K. here I go, this is another question while repainting my T. The last part I needed to take apart were the wishbones from the frontend. I was able to get the castlated nuts off but t stripped the treads from the wishbone bolt :suicide: Then while trying to get the bolts out I had to heat the axle and use a 5lb sledge, they finally came out but I had a few injuries to my hands from missing the bolt with the sledge :foottap: . I thought I'd have no problem getting the bolts but after looking through numerous web sites I'm lost. My spring hooks to the front of the wishbones in front of the axle?? All the ones I see are behind the axle and the wishbones only have bolts for the axle. I need new wishbone bolts and nuts also need to replace the upper shackel bolts and rubber? This pic is a little far away but I hope someone can help me with what I have. Thanks in advance.
