Welcome to Our Community
Sign Up
Dismiss Notice
Wood Floor Test Panels
Discussion in 'Bodies' started by B.C., Dec 19, 2014.
  1. Zandoz
    Zandoz
    Expand Collapse
    Apr 6, 2012
    1,142
    134
    Gender:
    Male
    Occupation:
    Retired eccentric
    I have a few reasons for focusing on the composite material rather than the plywood options. The first is that a big part of my income for several years came from replacing plywood floors in travel trailers and plywood decks on pontoon boats. There may well be plywood products that will hold up, but I never found one that I was really happy with. But that was 30 years ago <shrug>
    Next, unfortunately this car will be out in the weather...under a car cover. We have no garage, and nowhere to put one. My workshop is a small shed, and this thing will be built and live in the driveway.
    Then there is weight. This car will have a small V6 for power, and every bit of weight I can shave will be a plus.
    With the Coosa I can get a 3/4" 32x48 sheet for around $110 plus UPS shipping...to me well worth it to save 30% in weight and to eliminate any moisture worries. What I do not know is if the stuff is actually as structurally sound as a comparable thickness of plywood, as they claim. The good thing is I have a lot of time before it will be purchase time, and maybe by then there will be an even better option.
  2. Wyo George
    Wyo George
    Expand Collapse
    Dec 17, 2014
    54
    18
    Gender:
    Male
    no plywood will hold up on it's own. In boat building I fully encapsulate everything with epoxy and glass (even when I use foam panels...)
    Coosa is good stuff, I have used a little of it on small projects, I just don't see a benefit on the type stuff I do. It's nice to have options though!:thumbsup:
  3. jcunning
    jcunning
    Expand Collapse
    Dec 27, 2008
    267
    24
    Gender:
    Male
    Occupation:
    Director of Infrastructure & Operations
    Bob did say he was going to stress it until it breaks. I wonder if he will be wearing a mask when he does it.
  4. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Plywood rots even when encapsulated eventually. I have seen many rotted transoms and floors in glass boats.
  5. Wyo George
    Wyo George
    Expand Collapse
    Dec 17, 2014
    54
    18
    Gender:
    Male
    If done incorrectly for sure, but done correctly it will outlast either of us. When I build a boat every single hole gets overdrilled, filled with thickened epoxy and redrilled out. I have replaced many transoms and soles that were done incorrectly (cheaply) at the factory. They use polyester resin to save money and time and then drill into it without any thought or care of longevity. I'm fairly active amoungst high dollar custom boat builders and have built quite a few boats myself. You'd be surprised at the number of custom boats that are plywood cored, some costing close to or above a million dollars. Boats like a Spencer 60 pictured below:
    [​IMG]
    Source: http://features.boats.com/boat-content/2012/02/spencer-60-heavy-artillery/
    Sorry if I've derailed the thread, my desire is not to argue building materials, but rather to stress that whatever the job, the result is only as good as the workmanship.
  6. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Not to be argumentative, but every glass boat that I have owned, and I have owned several, eventually developed stress cracks in the jel coat and glass above and below the water line and moisture finds it's way in, not just through drilled holes, but that's a good point. Mind you those weren't six-figured or custom built boats, but they were very nice mainstream brand name boats from various manufactures. I've seen the same thing with showers and tubs. I suppose that you could make one good enough to resist the stress, but that's not the norm. They do last a fair amount of time though. Hopefully no-one will need to float test or bathe in their t-bucket to prove a point one way or the other. I think that good grade plywood embedded in glass is very well suited for flooring in a bucket and will resist moisture and be plenty strong. OSB embedded in glass is likely fine as well considering the fact that a lot of buckets only have plywood floors with no glass and last a long time. They typically don't see much rain, etc.
  7. Wyo George
    Wyo George
    Expand Collapse
    Dec 17, 2014
    54
    18
    Gender:
    Male
    No doubt your glass boats have developed cracks, so have all of my production models over the years. It's apparent that I should have made a distinction earlier and for that I apologize. Factory boats, shower units and other products are made from gel-coated polyester with limited support, even using cardboard stiffeners in some instances. The stuff I am referring to is only marginally related; about the same as building a doghouse could be considered "fine woodworking" ;) a vessel constructed using either epoxy-glass composite or cold molded is much stiffer then a FRP style production hull.
    At any rate, I apologize for the derailment of the thread. I'd gladly discuss the various fiberglass related construction methods in more detail, but further derailing this post would be impolite I fear.
    George (the new one)
  8. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    It's easy to get of topic, one thing leads to the next.
  9. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Tenn. Mason Jar about empty when drawing that 'picture'.
    RPM likes this.
  10. B.C.
    B.C.
    Expand Collapse
    Sponsor
    Forum Sponsor
    Oct 30, 2006
    282
    10
    I got my test panels done and will submerge them in water once a day and post daily pictures for a week. I'm not sure that will show us a lot but will leave the panels out side and abuse them there over an extended period and we will see what happens. test.jpg test1.jpg
  11. fish finder
    fish finder
    Expand Collapse
    Dec 23, 2014
    1
    0
    Gender:
    Male
    I am new at this but I have glassed standard CDX plywood for tower floors in boats that have lasted many years when left unprotected outside. I never glass the bottom of the plywood, only Gel coated the bottoms. I am rebuilding an old T Bucket and nothing is as it seams. Really enjoying the comments on this site.
  12. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Hello, With old cars, you never know what you will run into until you start taking them apart. Mine has left me scratching my head, wondering what the precious owner/builder was thinking. I think one variable that makes a big difference with wood/glass is if air can get to it so it doesn't just stay wet. It seems that the spots that rot the worst are in areas that have limited ventilation from my observation. CDX is rated for exposure, so that would add to it's longevity.
  13. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    B.C. if any uncoated edges of your test boards get wet , test is for naught. The water will sponge into /through the rest and swell under the resin coating failing to give best results. In my findings, completely covering the boards with F/G and resin they will outlast you. Make sure all holes you cut and drill are covered on the edges so no water or any moisture can get into the wood. The edges are where this usually happens, or holes cut/ drilled into it. Thicker the boards/ stronger they are. But F/G and resin strengthen thinner wood. Weight to strength is what we are looking for in this situation. The honey comb is a good choice IF it bonds with the body using F/G and resin . Different thicknesses of honey comb for different floor systems. NOT trying to tell you how to do it, just my experience with these types of wood and plastic/acrylic honey combs. Bruce
  14. James C
    James C
    Expand Collapse
    Jun 30, 2014
    63
    8
    Gender:
    Male
    Occupation:
    Paperwork monkey at a medical care facility
    Anything ever become of this?
    RPM likes this.
  15. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,716
    922
    Gender:
    Male
    Occupation:
    B.C. is a busy man. Making money is/should be more important than trying to right something that is/was not his fault. He'll post again when he has the results, I'm sure.
  16. hulkamania
    hulkamania
    Expand Collapse
    Sponsor
    Forum Sponsor
    Mar 6, 2008
    596
    136
    Gender:
    Male
    Occupation:
    Sales Manager
    yes BC has been busy. He has been building molds for a trailer hearse for another company, plus we built it complete for them, improving our molds, and building fiberglass parts. We have some much opportunities right now and it is keeping us on our toes. We are building 3 turnkeys for customers, trying to get some loose ends wrapped up, making molds better, and etc.
  17. James C
    James C
    Expand Collapse
    Jun 30, 2014
    63
    8
    Gender:
    Male
    Occupation:
    No worries. Glad to hear ya'll are staying busy with this cruddy weather. Just curious about the results. I have my own ideas about how durable each would be and was wondering if my ideas were correct.
Share This Page
SSL Certificate
