Welcome to Our Community
Sign Up
Dismiss Notice
wooding a body
Discussion in 'Bodies' started by akitagandy, Feb 17, 2009.
  1. akitagandy
    akitagandy
    Expand Collapse
    Nov 3, 2008
    488
    0
    Gender:
    Male
    What is everyone using to stick the wood to the fiberglass,and what weight fiberglass do you use, Do you use treated plywood fo the floor?
    Thanks
  2. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    I used Corvette Panel Adhesive it is an adhesive AND filler. A bit expensive though. I used regular outdoor plywood and you cover it with resin anyway.
  3. Wild Mango
    Wild Mango
    Expand Collapse
    May 15, 2008
    360
    28
    To get anything to stick to the glass you need to sand it to get the waxy surface off of it. Coarse discs don't clog so bad. Give the wood a scratch up too, while your'e at it.
    I have always used Epoxy resin to do this, marine shops will also sell you the glue powder to mix in the resin to thicken her up. You can also buy a micro balloon powder to make a filler with the resin for when your'e finishing off.
    Recently I have been using builders glue, which is a single pack and comes in a gun cartridge, to glue wood onto the glass. Works like hot damn, you still need to sand the surface and of course the fit up needs to be good, the builders glue won't gap fill. Sticks fine, but.
    If you have gaps use epoxy thickened up with glue powder, you can stop it running out as it sets (it goes runny as it sets) with race tape "dams"
    Use exterior glued ply for the floor, doesn't have to be treated since you will ultimately glass or resin coat the whole thing to waterproof.
    Chop Strand Mat is the stuff to use to reinforce, say 4oz. Epoxy doesn't "wet out" the glass very readily so while you are at the marine shop get a lay up roller, which looks like a stack of 1" washers. Rolling the wet glass really helps the wetting - if its not wet properly strength goes away. Get a couple of gallons of Acetone as well, its a solvent you'll need to clean up your brushes and rollers.
  4. bobscogin
    bobscogin
    Expand Collapse
    Jan 26, 2009
    118
    1
    3M Marine Fast Cure 5200 Adhesive Sealant
    A faster curing version of 3M Marine 4200 Adhesive Sealant. The high performance polyurethane becomes tack free in one hour and fully cures in approximately 24 hours. The seal is extremely strong, retains its strength above or below the water line. Stays flexible and allows for structural movement. Has excellent resistance to weathering and salt water. Easy to apply with manual caulking gun.
    Bob
Share This Page
SSL Certificate
