Anyone feel they are an expert on the 200-4R? I've been roaming the web and seeing all kinds of conflicting info re how and when they lock up the converter, and which lockup kit, if any, is the best, and what mods one should make to the tranny. It seems you can lock up manually, and/or by vacuum, or road speed or timeout after going into 4th gear. And what would be the best setup for a typical bucket (2000#, 400hp, cruising and some highway). And how important is the TV cable?
All I'm using is a adjustable vacuum switch for lockup that cost $29. There is also a 4th gear pressure switch that keeps the TCC from locking unless it's in 4th gear. I'm not using the brake switch to unlock at this time. I've not had any trouble with the TCC hunting either. I want to also install a manual switch to lockup the TCC in 2nd, 3rd & 4th, like that shown in the schematic below.
You may have already read this page, but it's the best info I have found on this subject.
http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
More info:
http://www.73-87.com/7387garage/drivetrain/lockup.htm
Below is how I wired my TCC, except I don't have the manual switch yet. That will come with my complete wiring project.
Below is the pressure switch used and also noted on the drawing above.
I did complete all wiring inside the pan and this is what it looks like.
I'm using the BTO TV cable kit with the braided SS cable housing, looks just like the Lokar cable. For me it did require some modification to the carb mounting bracket, but now it works without a hitch. Part of my reason for buying the BTO system is the compatibility with the Demon Carburetor. What carb are you using??? The kit is shown below.
Adjusting the braided style cable and BTO system can be seen below in their webpage.
You will need to verify your TV cable adjustment with pressure tests. This will require a gauge that can read 0-300 psi.
http://www.tvmadeez.com/tvcable_instructions/braidedcable.php
This is the kit I purchased from Amazon.
If you don't plan on going above 400 HP, then modifications will be mild to moderate in nature, but needed none the less. Talk about that in another separate post if needed.
What transmission are you running now?
